Old 08-07-2012, 11:30 PM
Xavier's Avatar
Xavier Xavier is offline
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Jaydee, you are referencing a hydraulic slave, I have no slave, no fork a throw out bearing that is engaged by pedal hydraulic. You have to limit the pedal movement as to NOT blow out the hydraulic bearing seal as it will over extend. The benefit of the HTB is simplicity, the downside is if something fails you have to pull the tranny.
Xlr8or,
When purchased, after looking at the design when new, I considered the strengths and weaknesses of the weights you refer to and removed them. The benefits did not out weigh the weakness in my opinion, and never regretted taking them off after talking to Center Force. Just one less thing to fail.
I will look at it this weekend, just hope it's not th clutch diaphragm.
