Old 08-08-2012, 07:10 PM
400TT's Avatar
400TT 400TT is offline
Peter, checked our shafts here and the nearest shaft length we have is 325mm. Just on the short side, they were left over from a project, so the price would be right. Then we jump to around 400mm.
Will also run floating CV's on each end, so no problem there. Also same CV PCD you are using.
Can you drop me your contact details via PM or email as we could quote you on some custom made shafts. We supply custom length shafts all the time. I also would like to confirm the way you are measuring the shafts to check the length will be correct, I expect it is, but worth checking all the same.
www.absolutepace.com
