Old 08-11-2012, 07:41 AM
olddog olddog is offline
Bobcowan & Funfer2
I like the routing of the wires from the distributor. It stays in front of the heads and then turns and runs beside the head above the plugs. That would take longer than a standard wire (I think). Do you get wires for a 460 or do you get the kit and put the ends on yourself?
I expect the insulation boots are a good idea. Depending on taste, not the prettiest things. Did you consider wrapping the headers with insulation instead? Pros and cons?
Thanks
