Old 08-11-2012, 07:44 AM
rub35's Avatar
rub35 rub35 is offline
Cobra Make, Engine: ERA 758 482FE
Originally Posted by madmaxx View Post
These are simple cars, no antilock brakes, ac, computers. If you can't fix simple problems cobra may not be for you. I had turn signal probs, fuel level gauge, term broke on coil, loose bolts, as you can see not brain surgery but if you have to take in every time to a mechanic could be a real pita! Ground cable broke in trunk, easy to fix but thank god for this forumn to tell me where to look Blas.
Pos oil pressure gauge fitting leaked, if your is yellow replace with braided stainless. Clutch reservoir leaked, seep rated and used seal all on o ring, a lot of sheet that should not happen on a 45k roller!
Not at all worried about that type of stuff. I can fix just about anything. Just wasn't sure of the average build quality on the SPF's. Sounds like they are very high quality and most owners are completely satisfied.
