Thread: MSD atomic EFI
Old 08-11-2012, 07:49 AM
whichonetodrive's Avatar
whichonetodrive whichonetodrive is offline
Cobra Make, Engine: # 238 lonestar w/IRS rear end
thanks for the replys, from what I understand lone star performance here in dallas has installed over 30 with no problems other than a car that had over 650 hp. which required a higher pressure fuel pump, my car already has a electronic fuel pump so just replacing with the fuel pump that comes with the kit.
MSD does come with a hand held controller for set up and they told me it can be used to calibrate the system for smooth driving.we called MSD and they said it will work with no problems with my Mallory unilite, really only sounds like I have to pull the exhaust and have it drilled and tapped for the O2 sensor and a return line to the gas tank,which they tell me is needed due to the heat we have in texas. should be a fun week. I will post on how it goes during the week.
Life starts when the little needle goes past 6,500 rpm's
