Old 08-11-2012, 07:49 AM
TButtrick's Avatar
TButtrick TButtrick is offline
Did you replace all those items because it was running rough or did it start running rough after you replaced the items you mentioned?
Did you check base and total timing with vacuum removed from dizzy? (if applicable)
Is the coil you replaced the proper primary resistance for your ignition? 1.5Kohm or .700Kohm?
