Old 08-12-2012, 12:30 PM
Bobcat Bobcat is offline
I had a friend of mine shear me 4 aluminum plates that are 16 x 16 and .060" thick .... just add grease between two and use them under the front ( or rear ) and this will also allow the suspension to move/settle freely . Like Bob , I also use the Longacre gauges ... just take your time . One other point , if your garage floor isn`t level , it will throw your readings off . You can shim the turning plates to get them level to each other .
Can you get to your frame/chassis rails easily ? If so , you can use them ( assume they are straight ) to string to car for toe in/toe out setting . Pretty accurate as that`s the way a lot of the stock car boys do it .
