Old 08-12-2012, 07:56 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Dangerous Doug View Post
Cruising home from work on Friday evening, travelling up the infamous Hwy 17 from Silicon Valley toward the Santa Cruz coast. I get up the first hill just putting along and I'm next to the Lexington Reservoir when without warning my engine dies completely.
The traffic was pretty thick but I was able to coast my way to a wide area and stop. I've never run out of gas before, but my needle was a little low. Popped the air cleaner off and checked for fuel. All is well.
Hmm, electrical then? I ponder the situation a bit, then get my tool box out of the trunk and dig out my trusty DMM. I turn the key on and check the voltage on the + and - sides of the coil. 12 Volts, both are positive.
My coil has failed.
I've been down this road before, only with a Volvo. I let the engine cool a bit and once cool, fires right up. I'm able (stressfully, very few turn outs or wide spots in the road) to drive home over the hill, and then I go purchase a new MSD Blaster 2 coil at the local shop.
So, when I installed this engine I purposely had a friend machine a coil bracket for me which holds the coil straight up, as the Blaster 2 is oil filled. Anyone else have issues with the Blaster 2? This one only lasted 4 years, and almost left me stranded.
Glad I had that DMM in my trunk! I saw four other cars on the side of the road as I drove home, each of which the very tired looking drivers waiting for a tow truck!
DD
Key on, engine off, you will have 12v both sides of the coil if the distributor "switch" is off.
Gary
