Old 08-14-2012, 03:35 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Werner,
The earlier Superformance chassis are all in South Africa. (Chassis #1, #7, #10). Chassis #11, #15, #16, #19 are also on the African continent. Chassis #23 was the first sent to the USA. The other missing chassis numbers were probably factory mules used for development.
I believe yours was the 1st chassis sent outside SA.
Are you a new owner of this chassis? I ask because you are not listed on the owner’s registry as the current owner. I believe your #011 is red with a wood dash, solid rear axle and RH Drive...
If you send me an email off line, I can help you get registered as the current owner on the Owners Registry. I can also tell you a bit more about your car but man who runs the Owners Registry can tell you more. My contact info is below.
SPFWiringDiagrams@Comcast.net
