Old 08-14-2012, 03:17 PM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by sideshow View Post
U don't really need speed signal into ecu
It's just for fine tuning the cruising speeds mixtures
U just need a sensor somewhere to suit your speedo
If u do want to run it to ecu just cut every second lug of the 40 pulse ring
Saves buying the Dakota unit
Im actually thinking i could just cut my own wheel with 17teeth and use a gm sensor. Mount the wheel on the diff pinion of the jag rear.
I read that it needs vss for evap solenoid and fuel cut off when decelerating for economy.
