Old 08-15-2012, 08:53 PM
menace1 menace1 is offline
Default Be prepared for anything and everything.
I was stranded twice by a rocker backing off and intake gasket leaking. Both times I was only a few miles from the house and had AAA tow the car to my garage. Then leaks a plenty with antifreeze leaking at hose connections and oil from valve covers and the pan. Also had leaky slave cylinder.
Pedel height adjustment to eliminate reverse grind and a new Jordan shifter to make 3rd gear shifts every time. Corner weight the Cobra after adjusting ride height made it handle 100% better and the list goes on and on...
Glenn
