Old 08-17-2012, 09:31 AM
DAVID GAGNARD's Avatar
Thanks for a good explanation. I'm suspecting the temps were not too high for your usage. Although 275 would get my attention...
I'm assuming you were/are using synthetic?? Or just straight 50W?
Yes, 15/50 Mobil 1 synthetic.....Most synthetic oils are good for temps around 300 degrees and most conventional oils are good for about 230 or so degrees.
I only saw 275 degrees of oil temp once, 90% of the time my oil temp was in the 230 to 250 range.......still a little more than I would like to see,I'd prefer the temps to be in the 220 to 230 range...
and the 275 temp did get my attention,big time, and I thought about it for a few seconds,I could have backed off the gas a little and the temp would probably have gone down some,but at the time,I was in a tight points battle for the track champoinship in my class and I was running in 2cd place with a couple of laps to go and could see the 1st place car and I was gaining on him pretty good.....
David
DAVID GAGNARD
