Old 08-20-2012, 04:23 AM
Neutral
Default If you go to a tire store--
I have used a tire balance machine to balance my setup. They have adapters that will allow you to balance anything if the center hole is clean without burrs. Static is a good place to start but spinning the assembly is better also if you have the clutch plate centered in the assembly. off centered off balance.
