Old 08-20-2012, 04:31 PM
ERA Chas ERA Chas is offline
Originally Posted by Cobra #3170 View Post
It appears that it had some ring gear tooth damage and the track session finished it off. (One person in my vibration post said to check the gear, and he was right)
It gives me NO satisfaction to say that was me.
Been there, done that but spared your near tragic consequence.
The old sayings about the Nut Behind the Wheel and The Red Mist applied here-and at one (or unfortunately more) time or another we all made less than good judgements.
When I suggested it, I figured dropping the fluid and cover off the diff to look-see the R & P would be 5 minutes compared to the toil you already went through.
Glad the coolant snafu didn't get worse than a hair-raiser on track.
Hate to sound like a fanboy but I'm passionate about your car because I think it is a seminal example of what all Cobras (and their serious owners) should be. A constant work in progress to improve and compete against equipment four+ decades newer. Morris' car is the only other project I deeply respect but he started with a clean sheet of aluminum and you started with an early, original and valuable core.
When I found my broken ring gear, I went straight to Bontoft's heat treated and HD parts which proved bulletproof in my application. But I put nearly 150 less HP into them...
BTW Bruce, which 'vintage' tires did you compete on??
Chas.
