Old 08-20-2012, 05:29 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
I started under the assumption all was well and the carb was adjusted mostly correct. Should have known better. I will start from square one and go through the initial install instructions and check all of the typical stuff. Should get it done this week.
My timing is spot on. I checked that against the builders suggestion and it is right.
I will go through the check list this week and let you guys know what I find.
John
