Old 08-22-2012, 09:39 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Originally Posted by Tommy View Post
Kevin,
It's hard to tell from your post whether you've figured out everything about your brake system except the number of pistons, or if you think that is the only brake system issue that matters. The most important thing about pistons is the total area they cover. A larger number of smaller pistons merely allows you to get more total piston area inside a smaller diameter wheel than a large piston would require. ... So I suggest you get whatever number of pistons in whatever size they need to be to both stop your car and fit within your wheels.
If you haven't figured out all the rest of your braking systems requirements (e.g., rotor diameter and thickness for stopping torque and heat dissipation, pad material, master cylinder diameter, pedal ratio, etc.), you need to do that before you finalize your piston decision.
I have a letter of intent from the VP of SSBC for a brake system for all the advertising I'm doing for them. The details of the appropriate system will be discussed in about in 2 weeks, when the gentleman I'll be working with returns from vacation, so I want to be ready to speak options.
I would assume it's going to be a 4 piston up front and 2 in back. The VP mentioned if I'm not happy with their brake pads for my application, feel free to choose another brand or type.
I'll fit as large of diameter and thickness of the rotor as a 15" wheel is capable of. The slave cylinders are 1" and 1.375".
Regards,
Kevin
