Old 08-22-2012, 09:01 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
I don't think you will be able to fit any 6 piston caliper inside a 15 in wheel----
the four piston calipers are thick and will determine the offset/clearance needed in your wheels--
A two piston floating caliper will give you the most room inside your wheels
Are you saying the MASTER cylinders are 1 and 1.375? if so you probably won't be able to push the 1.375 enough to stop-----are you meaning the rotors are that thick????/ doesn't make sense that the slave(calipers would be that size)
