  #26 (permalink)
Old 08-25-2012, 09:34 PM
PLDRIVE PLDRIVE is offline
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
Take your time when planning your brake upgrade (a lot of factors to consider).
Here are few key points (no brake booster).
What is your pedal ratio.
Do u have enough fluid volume from your master cylinders to supply you Calipers??? Try to use smallest master you can that will supply enough volume for the calipers. Not enough volume = NO BRAKES
Use the largest rotar u can (u will gain mechanical advantage)
Buy a 2 piece rotors ( less likely to warp or crack also helps to keeps the heat away from bearings)
This is how u find pressure.
P = pedal ratio
L = Leg pressure in pounds
A = area of you master cylinder
F = output pressure of your master cylinder
P X L /A = F
example 6.0 pedal ratio, 100LBS pressure, 7/8 master
6.0 x 100/ .6010 =998 Now divide by 2 (2 master cylinders) = 499
pounds of pressure applied (based on 50/50 balance bar)
Good luck
Mark
