Old 08-30-2012, 11:32 AM
Rick Parker's Avatar
Recently I was working on a vehicle that had the electric choke attached to the (+) Positive side of the coil. This was on a Mopar that has a Holley put in place of the original Carter 4bbl and had an OEM point type ignition. It was working but I do not think that is the best place to pull the current from as it could compromise the secondary ignition. It would be better to pull the current from a switched circuit on the fuse panel.
Rick
