Old 08-30-2012, 01:23 PM
patrickt patrickt is offline
Originally Posted by ha_pe_1968 View Post
Now i find out that the voltage regulator is not connected. There is a plug under the regulator with 4 wires. The wires are jumpered.
The voltage regulator is not plugged in and, instead someone has jumpered the wires that would have plugged in to it (that mostly run to the alternator). That's got to be an after-market switcheroo by somebody -- it couldn't have come from SPF like that. What's the make and model of your alternator?
EDIT -- When you check the make and model, it's probably a single wire job. Did your dashboard charging light ever work correctly? Or not at all?
