Old 09-01-2012, 10:24 AM
zzmac's Avatar
zzmac zzmac is offline
Cobra Make, Engine: Superformance, Roush 402R
Default Which Gaskets Do I need?
I've got a small leak coming from my water pump gasket. It's on a Roush 402. I haven't removed it yet but there appears to be a thin metal plate behind the pump and then the gasket. Any special gaskets being used for this nowadays or just a regular gasket will do. Anyone have a part number (Napa / Ford)) for me.
Also I might as well change the gaskets on the piece under the expansion tank that connects to the block. Any part numbers for these two small gakets?
Do I need to bother with gasket goo too or just put the gaskets on dry?
Thanks in advance for your help.
