Old 09-04-2012, 03:11 AM
Default Fun trip
347stroker Tom Like others have said, a basic tool box with a compete MSD distributor. If it's the other one, do the same. Coil and fan belt should be about it. Make sure the oil levels are full in the trans and rearend. Go over the car and do a quick check of nuts and bolts for being tight. If you have anything loose, a 500 mile cruise will knock it off going through NJ and NY. They are doing construction on both GWB and Tappen bridge at night. I would tell you to leave real early to hit these bridges before traffic gets clogged. Don't forget, Football and Baseball games also cause more traffic. I hope it doesn't rain. Stop about every 200 miles for gas and yoga. Have a safe trip. If you have a problem you have a bunch of CC guys along your route. Gas $3.70 per gallon. If you go Parkway and pay cash the toll booths are 3,4,5, and red signs going both ways or look for a line. Safe trip. Ps I guess you have done LOF and grease front end?? Make sure front wheel bearing are just a little bit of play and not alot. If you have time this would also be a good idea to do. Later Rick L. Pss I will listen for you to go by on the NJTurnpike. Or you can stop at the Molley Pitcher. I live behind it, about 1,000 yards. Phone # 732-254-3536 if you run into trouble. I work friday.
