Old 09-05-2012, 01:18 PM
ERA Chas ERA Chas is offline
Originally Posted by kevins2 View Post
Lots of good information in there that does indicate that the 6 pin system is superior, but $2,800 better? I'm confident that Peter and Doug will steer me in the right direction, which so far is that the 6 pin set-up is a worthy investment.
First off-I've only had the 6's. Reason is, my wheels only came that way. But the car was originally built with bolt-on's and I bought the 6 pin hubs and spindles from Peter in about '92.
Like Rick, I'm not a fan of hanging adapters on suspension points-for weight, machining, offset or anything. Yes the money is a notable difference but I figure you can also piss that much away on heaters, tops, curtains, Smiths or similar fru-fru. I rather have a non-goofy wheel attachment. No knock on the other guys who have had 5's trouble free.
I notice in your posts that you seem very concerned about 'wheel indexing'. Fear not-it's no big deal and you should do it no matter which you get. Here's how I did it and it's cake:
Using 'White Out', make a simple dot or straight line on the edge of the hub. Then when lifting the wheel on, orient the tire stem with the mark you made. The WO stays a long time and you always put the wheel on the same way:
Further, mark each wheel back with a label or dot(s) to ID R/F, L/F or D-river, P-assenger, etc. Same wheel goes on the same corner every time in the same relation to the hub. I did that because the mag transferred metal and I wanted to keep them 'mated'. Worked perfectly for two decades.
See the label 'P'? Label the K/O's too-can't hurt.
Chas.
