Thread: Mcloed BH
Old 09-05-2012, 05:24 PM
cobrafx cobrafx is offline
Cobra Make, Engine: Aussie 351C, TKO, UNK maker
Never used a McLeod bell, although I'm a distributor for them, so I won't be any help there.
However, if you look inside of it, it will either have two bolts on the driver's side for a driver's side pivot, a larger hole on the passenger side for a passenger side pivot ball, or both.
If it has that passenger side hole for a pivot ball, then yes a Fox Mustang clutch fork can work.
Cool. I need to pull the engine and trans soon.....just rough bolted together for the trip from WA so I will look at what it has. Many thanks for the reply. Hell, I dont even know if the trans is good. It was bought new and sat a long time. I have my work cut out for me.
Jaime
edit: will the hole on the pass side be threaded?
