Old 09-06-2012, 04:12 AM
Rob. Smith Rob. Smith is offline
G'Day Peter, as far as I can remember since I played with my old 210 import the only requirement was the 4"-100mm ground clearance rule and the fact that the cars ride was acceptable. The total travel of the suspension component should determine what you can do with your body mods. Set the car on stands at the correct ride height and remove the springs and shocks. Move the wheels through their travel range and see what happens at both stops. There are rules regarding suspension mods though. That applies to modified suspension components ( cutting and welding etc. ) You must be working with a signatory engineer though....ask him. Good luck.
