Old 09-08-2012, 03:23 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
There are 1000 horse Mustangs running 8.8's and living. If they are built right you shouldn't have any problem with it. It's hard to say where the weak link will be, if any. My thoughts are, run it until something breaks, then you know. Otherwise your just throwing money away, because you don't know if it truely needed upgrading. You could scribe a line the length of your axles, and periodically check to see if the line is straight or starting to twist, then you know that the axles need to be upgraded. All that being said, I don't think you'll have any problem with the 8.8
Jack
XSSIVE .....
