Old 09-08-2012, 04:02 AM
mdross1's Avatar
mdross1 mdross1 is offline
Originally Posted by Hotfingrs View Post
There are 1000 horse Mustangs running 8.8's and living. If they are built right you shouldn't have any problem with it. It's hard to say where the weak link will be, if any. My thoughts are, run it until something breaks, then you know. Otherwise your just throwing money away, because you don't know if it truely needed upgrading. You could scribe a line the length of you axles, and periodically check to see if the line is straight or starting to twist, then you know that the axles need to be upgraded. All that being said, I don't think you'll have any problem with the 8.8
I agree especially since the car is already on the road.The day you decide to assault the drag strip on a regular basis then maybe you should consider a 9" otherwise paint that line on your current axles.
