Old 09-08-2012, 06:27 AM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
I have a older front bumper from Finishline and it has tabs on lower hoop with a rod that goes through them and tabs on license frame tabs with a spring that holds license vertical until you start driving , then wind pressure against plate pushes it down to the lower nose opening. Two small rubber bumpers protect paint on lower nose. Cheap spring broke right away but a AR 15 trigger spring works just fine.
