Old 09-08-2012, 07:11 AM
madmaxx madmaxx is offline
Another thing, install a 195F thermostat if not already. I found the engine would not get above 160 in the freezing Houston winter months. That was horrible, cold cylinder walls and hot piston equals excessive wear. Forget about the pipe dream cold make more hp on the coolant, yes on the air side. Mine was an 180f, with a hole for an air bleed. I found thermostats open at there rating but dont fully close for 10 degrees below. I guess the spf cooling system is so good / large I had ample cooling with a tiny hole in the 180F. I tried numerous 180f thermostats and all the same result very slow warm up and never above 165F except summer. Now with the 195F I warm up and 95% of the time in summer I am still only at 180F!!!! yes I checked the accuracy of my temp guage and it was dead on!
