Originally Posted by razerwire
I have a older front bumper from Finishline and it has tabs on lower hoop with a rod that goes through them and tabs on license frame tabs with a spring that holds license vertical until you start driving , then wind pressure against plate pushes it down to the lower nose opening. Two small rubber bumpers protect paint on lower nose. Cheap spring broke right away but a AR 15 trigger spring works just fine.
That's a great solution! I have a hoop bumper on the front of mine, but no tabs. At some point I may want to use an
oil cooler, and when that happens I will want to clear the opening for my cooler scoop....will attempt to adapt your idea to my system.
Thanks!
Cheers!
Dugly
