Keep in mind that the running gear, suspension, etc, that you plan on switching over to a new frame, would be easiest, if it is designed for what you currently have.
The FFR's basic frame is designed with Mustang 5.0 or the later later Mustang 4.6 components in mind. Not Mustang II. Common rear end used in the FFR is a 8.8" Ford. You can also order a frame designed for IRS. FFR can also supply a frame with mounts for a Big Block, or a SB Ford.
Cobra-fast at any speed!
