Thread: IDF Tuning Help
  #22 (permalink)
Old 09-08-2012, 11:34 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by jabbott View Post
Couldn't I just keep the same tubes and lower the air jet (same thing as a high speed air bleed on a holey) which would also richen up top, then lower the main jets to get the afr I want.
Yes, you can do that. Main jet ( and to a certain extent, the emulsion tube ) determines A/F ratio at low rpm, air corrector at high rpm.
Emulsion tube affects the "curve" of the A/F ratio between low and high rpm during acceleration.
Theoretically you could nearly obtain the the correct A/F ratio throughout the throttle range with the correct main/emulsion tube/air jet, and then less accelerator pump shot required.
One book of mine states to run air jets in the 60-80 range, then pick the main jet, then choose the emulsion tube. This is all after the correct venturi is chosen for the application.
Gary
