Old 09-09-2012, 03:04 PM
sideshow sideshow is offline
i would probably run a hose from charcoal cannister to engine but put somehting inside
hose to block it so it looks like it works but it doesnt
i think the valve opens just off idle
maybe hook it up with valve there but just run fake wires to it and tape them to harness
doubt they will know if it works
speed sensor wires will porbably be orange/black wire and a blue/white wire
crank sensor wire is between starter motor and block
get under car and look up the 20mm gap between side of starter and the block
make sure wiring doesnt touch headers when u eventually plug it in
its the hardest plug on the lsx motors to get on and off
it should be on the section of wiring that goes to the drivers side knock sensor
my website
www.sideshowsperformancewiring.com.au
