Old 09-10-2012, 07:20 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
ALSO---------there have been instances of valve seal deteration and break up into little pieces that then blocked the oil flow return path in the cylinder heads and valley under the intake so that the oil can't get back to the pan---removing a valve cover will expose evidence of this
Also, when this happens, particals will find there way down and into the pickup screen on the oil pump blocking flow into the pump
