Old 09-10-2012, 09:18 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
A fact that most of are overlooking is that an oil pump will not pump more oil up/around/thru an engine than the clearances will aloww to pass---the pump has an relief valve that will bypass the oil flow and it will stay right in the pan---
Biggest issue with high volume/hipressure pumps are blowing oil filters when cold-----
