Old 09-10-2012, 03:33 PM
patrickt patrickt is offline
Originally Posted by kgs365 View Post
So against Peters wishes instead of the BMW fluid reserve I bought the billet kirkham canisters...there is a 3 inch rubber hose with clamps on each end that connects the hard lines to the canisters...I have one line that I can not stop a leak from seeping up one of the clamps and dumping fluid ?....any ideas on how to stop this?...ive tightened the clamp to no success...I've moved the clamp position no luck etc...any ideas?...please
These leaks can fool you -- don't always believe your eyes. Put strips of paper around your canister and fasten them with a black pinch type clip that you use at the office. What you want to eliminate is the possibility that you're getting a slight splash out the top of the canister and it's leaking down the side and fooling you. Put little strips of paper right above the rubber hose as well, in the same fashion, to confirm the leak is not coming from the fitting at the base of the canister. Use plain white printer paper -- brake fluid stains it nicely. Once you've done that you might find that the leak is not coming from where you thought it was.
