Old 09-10-2012, 05:53 PM
patrickt patrickt is offline
Originally Posted by kgs365 View Post
put a dab of that then slide the rubber hose on the metal brake line?...you are probably right that the leak is coming from somewhere else....i might just try another clamp ...they are the small ones you referred too
thanks
Kevin
Brake fluid, more than any other fluid, looks like it is leaking from a place that it's really not leaking from. Spend the extra time finding the source. For teeny, weeny leaks I found that the tissue paper that your wife wraps presents up in works astoundingly well at disclosing even the smallest leak. A really small leak of brake fluid can really fool you. Here's an example that I posted over four years ago: Guess the Origin of this Leak - Lame Entertainment
