Old 09-11-2012, 02:45 AM
Zedn's Avatar
Zedn Zedn is offline
Running without the purge valve will not effect emissions. The problem will be that un-metered air is coming in the whole time so i suspect would be similar symptoms to an air leak.
Do you know if the valve is normally closed or open without power?
Perhaps a relay can be hooked up using the signal from another sensor that only works when the car is driving.
