Old 09-12-2012, 11:47 AM
LRcobradreamer LRcobradreamer is offline
I have rented at U-haul several times. Some points to consider.
1) You want the car hauler open trailer; they do not have enclosed trailers.
2) The car you are hauling is a Shelby Cobra 427. They will have that in the computer and will not find any replica. Or tell them it is a 65 Mustang if they cannot find the 427.
3) When loading, suggest adding a block under the ramps to reduce the angle and crank up the front of the trailer to do the same. Then watch the license plate on the trailer, it can touch the front of the body when loading. Some of the plates are bent over, likely because others found the same risk.
4) I could not get the U-haul straps to fit my big tires in the front, so I had to buy straps for front and back. Use “duck tape” to tie up loose straps material. I could only find 25 foot straps at the time.
Good luck
Lee
