Old 09-12-2012, 02:15 PM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
With an internally balanced rotating assembly, you will be OK with a clutch/ flywheel and a balancer with zero /neutral balance.
However, to be on the safe side- take the whole assembly for a check. My 2 cents...
As Rick, I did the flywheel in wheel balancing machine. However- I sent it to the engine shop who checked it. Not very expensive job. 200 euros is what I paid.
Good thing you're getting the engine back together, Eljaro.
