Old 09-13-2012, 01:33 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by PLDRIVE View Post
Brent why would U need a Pop off valve in the drivers side valve cover if u are pulling a vacum ( I'm assuming Daileys pump is a multi stage rotor)? How could an overpressure event occur unless oil pump fails?
Mark
The pop off valve is for a sudden pressurization of the crankcase... such as when you burn a piston. Helps prevent blowing the pan off and making a mess on the track.
