Old 09-14-2012, 02:10 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jon:
I did not do the area behind the seats because I wanted as much room as possible.
I also did not do the trunk. Both areas only have carpet.
I did insulate all surfaces of the footboxes, half the floor and the tunnel.
I did not do the floor under the seats.
I guess, it is what you feel you need to insulate.
If you are thinking to insulate against the heat, then what I did was about all you need to do.
If you are insulating against road noise, let me tell you that the NOISE coming out of the sidepipes no more than a couple feet from your ears, will be louder than any road noise.
Jim
OhioCobraClub.com
