Thread: Alignment specs
Old 09-15-2012, 07:55 AM
FWB's Avatar
FWB FWB is offline
i use 77-78 mustang II, but with some changes, those changes are different from car to car based on tires, ride height.
what gets changed?
depends, the guy doing the alignment will have to fudge it as he see's fit.
on my car the caster gets tweeked.
on the mustang II's the motor sat right on top of the crossmember, putting the weight farther front, on our design cars, the motor is rearward of the member.
with all that being said, do you still have the ford stamped steel control arms on yours? by now they are how old? and were they new or used when the car was built?
if you find out its pulling because it needs upper arm bushings or maybe a ball joint, it might be time for a suspension upgrade. get it checked, if this is the case email me i'll give you a place and part numbers for what you'll need. i did it to my car a few years ago, and just did it on a 1980 kellison 2 weeks ago, makes a big difference in handling...
Fred
Fred B
