Old 09-15-2012, 06:34 PM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Originally Posted by sideshow View Post
Oil pressure don't worry bout
Remove the orig and fit yrngauge or lit sensor
Sideshow,
I removed the oil press sensor from the back of the block, but the sensor I have with my gauge will not screw into the same hole. The GM sensor is a larger thread than that found on the gauge sensor.
Can you enlighten me if you can get an adapter to make it fit, or is it better to use the GM sensor and just connect my gauge to it instead via the GM bulkhead connector output. Presumably I just connect to the oil press pin, and to ground.
Any help appreciated.
Thx
Tim
FFR Mk4 Roadster
HSV Clubsport R8
