Old 09-16-2012, 12:06 PM
bliss's Avatar
bliss bliss is offline
Originally Posted by strictlypersonl View Post
bliss's handle might be from a Jag sedan. Not one that we ever recommended.
If the original chassis bracket is still there, then our custom unit will fit.
I've verified with the seller (original owner) that the EB "was scavenged from a 1968 (I think???) E-Jaguar car being sold off as parts." He also stated that it never really worked all that well and that he "drilled a larger hole in the mount bracket and had to fit a bunch of washers to act as a spacer to get the brake handle to line-up correctly."
The original owner also stated that the original EB bracket is on the Cobra with the only alteration the larger hole noted above.
Therefore, is it safe to assume that the $250 EB entire kit that is offered by ERA will work on my Cobra? Will I also need to order the EB cable?
Emergency brake handle, chromed, ratchet fly-off, with bracket $250
Cable for above, Jag-based rear............................................ $50
If yes, is there a part number, etc. that I will need to order it? I assume that if it doesn't work I can send it back for a refund, right?
Thanks for your help.
