Thread: Tortilla Flats
Old 09-17-2012, 05:53 AM
Danr55's Avatar
Danr55 Danr55 is offline
Try running it without a thermostat in it to see if it runs cooler. If not then try changing the temp sender. If that doesn't help, try changing the gage. My black car would say the water temp was 260 but the oil temp never got above 200. Not compatible. Finally changed the temp sender and everything ran within a few degrees of each other. Water was always a degree or 5 higher than the oil.
Dan in Arizona
CCX3209
