Old 09-23-2012, 05:16 PM
cobrafx cobrafx is offline
Cobra Make, Engine: Aussie 351C, TKO, UNK maker
Default cnc/sb build help
Hello all. I think the engine is mounted too far forward. It was ordered setup for a SB Ford and has slotted motors mounts to frame. There are two pre drilled holes in the frame rails. The mounts are bolted currently using the rear most holes. I have yet to drill the remaining two holes as I believe the engine needs to go back. The 351C that is in it, locates the oil filter VERY close to the gusset for the strut arm. I dont think the filter would come off. If the frame mounts are mounted with the forward holes, I believe the two rear exhaust tubes would have to travel radically forward before exiting the side. How are your frame mounts positioned? Thanks
Jaime
I pulled the engine and trans before getting a pic. I can get some of just the frame and mounts........
