Old 09-24-2012, 08:19 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I like the durability of a C6...but no OD available, so the C6's final drive ratio is just 1:1.
If it were me, I'd go somewhere near 3.23, maybe even a bit lower. Your 460 has enough torque that your biggest problem will still be keeping the tires from breaking loose and you'll like the improved mileage and lower cruising RPM's.
The Ford AOD can be built to withstand some serious power input and has an OD...if you are not already committed to the C6 that might be an option to consider.
Are you sure you have an 8.8" live axle? I ask b/c if yours has a removable "pumpkin", AKA "center section", it is probably a 9". AFAIK, changing out the ring & pinion on an 8.8" Ford differential involves removing a rear cover and approaching the change that way, not as easy as removing a center section from the front of the differential housing and sliding another already assembled "pumpkin" in.
Got pics????
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
