Old 09-24-2012, 11:30 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Yes, Thats the symptom but only when fully hot with wheels off the ground, when clutch is depressed and in any gear, the output shaft still turnin the rear axle. It does not do this cold. Once I learned that the TKO 600 rev gear is not synchro'd. , when cold , if I select another gear before reverse, no more grinding into reverse, I get that part. The clutch disc now releases with pedal about 1 inch off the pedal stop. I must admit this testing is done with car elevated, no intertia load on drivetrain, have not yet go karted either.
"...some assembly required, ages 8 and up...... well that took longer than expected......
