Old 09-24-2012, 11:32 AM
blykins blykins is offline
Then I wouldn't worry about it now....you should have mentioned that it was up in the air at first. That's totally different.
If you want the clutch to engage a little higher on the pedal (I would...) you can adjust the bearing closer to the pressure plate.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
